HV320WHB-N85-32″ LED TV PENNAL NO DISPLAY SOLUTION
This panel often has an issue where it does not display. Most of these panels are standalone units made by Nobel and Global companies, and in many Chinese TVs the panel is programmed with an IC (integrated circuit).
When the panel fails to display, you can resolve the issue by copying the panel’s memory using a programmer. This process usually fixes the problem.
- Has thanked: 14328 times
- Been thanked: 1639 times
Re: HV320WHB-N85-32″ LED TV PENNAL NO DISPLAY SOLUTION
This isn’t a user setting issue ASTER’s multi-workplace isolation conflicts with the newer Snipping Tool’s capture method. That’s why it works only when ASTER is off. The only stable fix reported is using an older Snipping Tool or a different capture tool that doesn’t rely on Windows’ overlay system.Broken Display
