YouTube ReVanced v17.25.34 (Non-Root)(Mod Extra)(Mod Lite+UltraLite)
Requirements: 6.0+
Overview: Enjoy your favorite videos and channels without ADS and with Background Play on this YouTube app.
YouTube ReVanced is a Project Based on YouTube Vanced. Currently It's in initial Stage & Have Basic Youtube Vanced Features. As YouTube Vanced Project is Closed. Youtube ReVanced is supposed to Continue its Legacy Unofficially. No root is needed to install. No need to uninstall official YouTube, it can install as a secondary YouTube.
★ ReVanced Provided Patches-
amoled :
Used to output, a pitch black themed YouTube Revanced apk. If this patch is not used, then non amoled variant (material light / material dark themed apk) will be made.
minimized-playback :
For having background play as on by default, if the code is not used then background play will be turned off.
disable-create-button :
Option to enable or disable the Create (+) button on the home page of the app.
premium-heading :
Enable or Disable PREMIUM branding instead of YouTube text on the top left corner in the YouTube app.
custom-branding :
If this patch is used, the output apk will end up having "Revanced's logo" as app icon, if patch is not used, then you will have the original untouched YouTube App's icon in the apk.
disable-shorts-button :
For disabling YouTube's "Shorts" feature (similar to short videos like TikTok or Reels from Instagram).
hide-reels :
Hides reels on the page.
old-quality-layout :
Used for forcing the old quality choosing layout in the YouTube app. (240p, 480p, 1080p, 1440p.. etc, if your phone's display supports it). (This is equal to "Quality settings style" option enabled in Original Vanced)
hide-cast-button :
For hiding Cast option from the YouTube app (This is equal to "Cast button" option under Layout Settings in Vanced)
microg-support :
This patch is used to create non-root apk (hence supporting Micro-G), if skipped or unused, then root variant apk will be compiled as output apk.
general-ads :
To remove/disable all layout ads from the apk (home screen banners, ad links, etc).
video-ads :
To remove/disable all video ads from the apk.
seekbar-tapping :
Used to enable the option tapping directly onto the seekbar / video progress bar to seek in the video. (This is equal to "Tapping on seek bar" option under Misc in Vanced)
disable-fullscreen-panels :
Disable comments panel in fullscreen view.
★ Excluded Patches-
• hide-shorts-button (Result: Shorts Tab Present)
• custom-branding (Result: Original YT Logo)
• disable-create-button (Result: Create Button Present)
• hide-reels (Patch Doesn't Work)
• disable-fullscreen-panels (Result: Comments in Full Screen Present)
★ Compiled By RBMods
★ Applied Extra Mods-
• App Name Restored to Youtube
• Debug Info & corresponding .sources Tags Removed
• Optimized Graphics & Cleaned Resources For Fast Load
• Maximum Ads Links Removed/Nullified From Java Classes
• Google Play Store Install Package Check Disabled
• Google Play Services Check Verification Disabled
• Maximum Analytics/Crashlytics & Other Trackers Removed
• Mod Lite 65 MB (Org Size 161 MB)
• Unwanted Permissions/Activities/Services/Providers Disabled
• Split file & Other Trash Removed from Resources
• Compression Flags Untouched (No Ultra Super Compression Applied)
• No Third Party Patch/Hook/Component Applied
• Screen Dpi- Universal (m to xxxhdpi, All)
• CPU Arch- Arm64
• Language- MultiLingual
★ Modded By RBMods
★ Mod UltraLiteX-
• Based On LiteX
• Cleaned Resources Unnecessary Files
• Languages Removed (EN only)
• Mod UltraLite 54 MB, Org Size 161 MB
• CPU Arch- Arm64
★ Modded By RBMods
★ How to Install-
• Install ReVanced Mod apk
• Log In to your Account
• Enjoy
- Base updated to YouTube v17.25.34
- New revanced optimizations and fixes
This app has credit advertisements
http://ul.to/h4drtavk
mucahitdogan68
Has thanked: 10 times
Been thanked: 6 times
Re: YouTube ReVanced v17.25.34 (Non-Root)(Mod Extra)(Mod Lite+UltraLite)
Post by mucahitdogan68 »
Thank you very much
zapppa
Has thanked: 43 times
Been thanked: 86 times
Italy
Post by zapppa »
Wow..interesting..i stick with Vanced. I'll try
idou111
Silver Member
Silver Member
Has thanked: 18 times
Been thanked: 17 times
Morocco
Post by idou111 »
Thankyou for share it
leonkey
Been thanked: 1 time
United States of America
Post by leonkey »
"Vanced MicroG Unofficial(v2) is a Forked Unofficial Development of Vanced MicroG As its not getting updated from a long time. It's built by Inotia00 with the help of VMG Source Provided by Oxrxl. Vanced Microg is An Addon to Login in YT Vanced & Vanced Music(YT Music), ReVanced, RV Music, RVX, RVX Music"...
rachelpoole
Post by rachelpoole »
Find a trustworthy and reputable website that sells modded APKs first. To prevent installing malicious software or apps that can damage your device, be cautious to pick a reliable source. Once you locate the page, type "YouTube Blue APK" into the search field to discover the download link for the software that has been modified.
Ranksapk
Post by Ranksapk »
For trusty website that are providing latestYoutube Blue APK with all latest features and Blue theme.
leoa69
Argentina
Post by leoa69 »
rachelpoole wrote: ↑18 May 2023, 17:46 Find a trustworthy and reputable website that sells modded APKs first. To prevent installing malicious software or apps that can damage your device, be cautious to pick a reliable source. Once you locate the page, type "YouTube Blue APK" into the search field to discover the download link for the software that has been modified.
I think ReVanced is better than YouTube Blue.
dlsapk
Post by dlsapk »
Thanks for sharing this great information.
dlsapk
Post by dlsapk »
Embark on a quest to uncover a trusty digital oasis, where the mystical modded APKs dwell. Take heed and navigate this treacherous terrain with utmost caution, for the realm is plagued with treacherous entities. When you've finally charted your course, inscribe YouTube Blue APK [https://dlsapk.com/] into the scrolls of the search bar, and the elusive portal to the altered software shall be revealed.
